Recognise number of element added to array
_Y_
UI has an array. A new element can be added initialising one more element at the end or using menu "Insert element before". Both methods launch user event "Value Change".
Is any way to see index of newly added element? My guesses are limited to watching position of mouse clicks but there is no fun is such a solution.
Edited by _Y_
What I normally do is to compare Old and New Value and look for the first nonequal element.
If the new element is added at the end of the existing, off the head the boolean array will be short as the Old, but the increased length will asess the change in the last element.
Edited by ensegre
Unforttunalely, it does not work if a new element is iserted near an old element and both have default value.
The simplest example is inserting in Boolean array where all elements are False. The method will say that the element is added at the end independently on the actual insertion position.
Right. But then one could argue, is it really important to evidence where the mouse has been clicked, or just how the resulting array differs at all?
One workaround I could think (maybe), is the following: make an array of clusters, [ordinal,your_content], where "ordinal" is a flag, for example an integer which defaults to -1 and is set to the element number by the Value Change event. In the GUI you could hide "ordinal" if it falls in the way. Then finding the insertion translates into finding the first -1 in New Value, finding a deletion means finding a jump of 2.
