"Select VI Server Class" on Refnum Control programatically
PiDi
I have a refnum control on my Front Panel and I want to change its class. Easy (well, if you don't count four "wait-for-menu-open" moments in process) to do manually
Problem: How can I do it programatically?
This is as far as I got with this - I was sure there would be some property/method of LVObjectRefNum class to do it, but I was wrong:
 I've attached the project with this VI for the convenience  ;)
ChangeRefnumClass.zip
Control Refnums don't really work like that. It is a container that assumes the type of the contents a bit like ,NET and ActiveX containers rather than LabVIEW objects, per se. So you have to do something like this.
You will notice that by inserting the control into the reference; the reference now assumes the [type] name of the control.
ChangeRefnumClass Folder.zip
Edited by ShaunR
@Shaun: Nice catch, I didn't though of refnums as containers - now it seems pretty obvious (I forgot I can drop control on the refnum to change its type). However, there are two problems with the code on your screen:
1. The "style" input of New VI Object is a mess. I want to provide Class Name and nothing else, so I'd have to somehow decide how to translate the Class Name to style. I can think of couple of ways to do it, all of which would probably require a lot of coding.
2. This only allows to create GObject references. This is quite OK, because that's what I need for now, but my method allows me to create any type of reference (like ProjectItem, or Panel).
I see no problems. Only a solution to the question asked and the beginning of other solutions :)
