SubVI
  I want to run a continuous process. is it possible to put this vi as a sub vi in another VI, since i want to use 4 instances of this subvi at the same time.
4429[/snapback]
You want four instances that run asynchronously? One option
is to create a reentrant subVI and have four while loops,
each containing a call to the reentrant VI. Because it
is reentrant, each diagram reference will have its own
dataspace and can be called at the same time as any other
diagram reference. This is sort of like having four instances.
Another option is to place a static VI reference to a reentrant
VI, wire it to a VI property node that extracts the VI name,
wire that name into "Open VI reference" with the "prepare for
reentrant run" option mask bit set (mask value == 8) and call
the run VI method on the resulting VI instance reference. To
pass instantiation parameters you can call the "Set Control
Value" method on the VI instance before running it.
Neither of the above works when the front panel of the
instance must be visible/usable. For that, you must instantiate
a template (a VI with a .vit instead of .vi extension).
Templates may not be loaded in memory on instantiation,
so you will have to pass an appropriate path to the "Open VI
Reference" call (and call "run VI" on the resulting reference).
