Get error while writing to COM
tengels
Hi there,
I need some help!!! I want to read a displacementsensor through serial communication.
But i get a timeout error when the Visa is sending the string to the displacement sensor.
I've tried to enlarge the timeout with a property node. Still no result.
The string I'm sending is correct because it works if I use program hyperterminal to communicate with the sensor.
Please HELP somebody, I am probably doing something wrong and can figure it out. :headbang:
The VI is attached.
The error will occur in the VISA write (error 1073807339)
THNX
Download File:post-1757-1112791619.vi
just out of curiosity, are you sure there's no need for a termination character? <cr> or <lf> can be appended to your command string if necessary.
Regis
Hi there,
The VI is attached.
THNX
4449[/snapback]
I would agree with regis. The sensor needs something to tell it that the string is complete.
If it is not a LF or CR it could be a non printable character like hex 03.
Hyperterminal may be appending a nonprintable without you realizing it.
One of the programs I use is called port monitor.
It shows exactly what is being written and read from the serial port.
you can download it here
http://www.sysinternals.com/ntw2k/freeware/portmon.shtml
I would start portmon and then use hyperterminal and see what characters are being passed back and forth.
good luck.
Regis
4451[/snapback]
That would be a little strange it seems. Also you should consider that Hyperterminal actually adds a carriage return/line feed automatically to every line (after all you pressed the return key to tell it to send the string and the return key at least under DOS/Windows is equivalent to carriage return+line feed).
4554[/snapback]
Oops this was meant to be a reply to the previous message.
good luck.
4515[/snapback]
Thnx mballa with the monoitor I found out there was a non printable character. With the character the program works fine now.
greetings Theo
:thumbup:
