smarlow
Free LabVIEW WinSCP Library
Here is a library I created to wrap the WinSCP .NET library.  You can use it to connect to a remote server via SSH and transfer files, create remote directories,etc., with WinSCP from LabVIEW.  I know there is a commercial library for I think $500 a pop, but this is something that is missing from LabVIEW that really ought to be included with native functions in the file I/O palette.  The VI's in this packed library are built around the "WinSCPnet.dll" library that installs with WinSCP.  You will have to download and install WinSCP to get the DLL, as I do not want to distribute it without their permission:
Download WinSCP Here
After downloading and installing WinSCP, you will have to connect the VI's in the packed library to WinSCPnet.dll.  I make no warranties here, and no promises it will work, since I already have the stuff installed.   The use WinSCP with an SSH Key, you will have to generate a key and copy the public key to your server.  WinSCP uses the Putty format for SSH 2.  You will also have to obtain an SSH fingerprint from your server for input to the session.  Otherwise, you will have to provide user login credentials.  You can use the "C:\Program Files (x86)\WinSCP\PuTTY\puttygen.exe" utility to generate a key.  I use Git, so I used the SSH utilities included with that to generate and copy the key to my server.  If you do that, you will have to use puttygen to import your OpenSSH key and convert it to putty format for use with the WinSCP/LabVIEW library.  Sorry I don't have more time to do full docs and directions for use, but maybe someone else can comment with additional directions.  I will monitor this topic and try to answer any questions.   Good luck, and happy SFTPing!
PS: No I will not save it to an earlier version.  Maybe someone else can.
WinSCPnet.lvlibp
  • Like 2
Share this post
Link to post
Share on other sites
Here is a ZIP file if you want to change the code.  Please don't take this and try to sell it.
WinSCP.zip
Edited by smarlow
Recompiled ZIP file with fixes
Share this post
Link to post
Looks cool. I did something with the winscp dll a while back (just a simple powershell script) and it was pretty solid.
I was curious about licensing because I thought it was GPL -- turns out the exe is, but the .net library is not (in case anyone else is curious):
Quote
https://winscp.net/eng/docs/library#license:
The WinSCP .NET Assembly is a free library: you can use it, redistribute it and/or modify it under the terms of the Mozilla Public License Version 2.0.
Because WinSCP uses the GPL license it’s important to keep the GPL license file around.1 Your software doesn’t have to be licensed under GPL as the WinSCP .NET Assembly is using WinSCP as an executable, via its public scripting interface, and not as a library
That having been said, your code should specify and include a license: https://stackoverflow.com/questions/5521080/can-i-use-the-code-in-a-github-project-which-does-not-have-a-license-specified
Edited by smithd
Share this post
Link to post
The .NET assembly used to be distributed separately from the WinSCP application, but the latest version has them wrapped up in one installer.  The LabVIEW code posted here is merely a wrapper that calls the library, and does not incorporate any of the source code from WinSCP or its .NET automation library.  You are probably right that a license might be a good idea, but I view this as merely example code that demonstrates how to call the WinSCP .NET assembly from LabVIEW.  Since I am not distributing their DLL, I feel no need to include their license, since anyone who uses this LabVIEW code will get a copy when they install WinSCP.
Share this post
Link to post
Sorry, those were two separate points:
The first was just to say I thought the winscp library was gpl but it isn't, yay!
The second was to say that (as I understand it, not being a lawyer), even if you consider it an example, those of us who might wish distribute code/applications outside of their organization using this library cannot do so unless you specify a license.
Edited by smithd
Share this post
Link to post
Hi, I am glad that I found your library but would you mind saving it for Labview 2014 please?
Share this post
Link to post
Is there a way to use this as a virtual SSH terminal as well? I'm trying to communicate to a piece of hardware where it's only connection is via SSH terminal. Thanks for sharing what you have so far!
Share this post
Link to post
