DAQ Assistant Error
Ganguli
I think it would be hard to install DAQmx without MAX.  It is likely in your start menu as "NI MAX" if it isn't then that is probably needed to setup DAQ Assistant.  If it is missing, install MAX and you may need to reinstall DAQmx.  When DAQmx installs it looks at what things you have on your system and installs DAQmx support for those things.  If a thing is missing when DAQmx gets installed, it won't install support for it and you'll need to reinstall.  For instance if you have LabVIEW 2017 installed, and you then install DAQmx it only installs support for LabVIEW 2017.  If later you then install LabVIEW 2016 you won't have DAQmx support, until you run the installer again and it adds support for 2016.  During the second install it should see that 2017 support is already there and do nothing.
