Binary thershold like Vision Assistant
  I would like to threshold a binaty image showing to the user the original Image overlayed by the thershold result like the Vision Assistand does.
I've tried with the Keep/Replace Value input in the threshold VI but it does the exact opposite of what I need (it replace or not the thresholded image leaving BLACK the rest)
I need to replace the thresholded values with a user color and leave the rest of image as it is.
Any suggestion on How to do it?
thank you so much.
you have to do this method
use  thershould vi to time
1 use for it for rest of range with replace value that you want (0 up to 255)
2 use it with range that you want and make of for replace value
now you need just to add this two  picture to each other
At the moment I solved using IMAQFillImage VI.
That VI allow, using a binary image as mask to determine which pixels has to be overwritten, to do what I need.
Beeing an 8bit grayscale image it allows me only to choose 255 gradients from black to white, but converting the image in a coloured one, it allow to use every color I want.
