farzane lk
"We don't know the Compiler" Error from platdefines.h in Matlab
Hello
I have received a LabVIEW dll and the corresponding header files so that I can send a trigger to a skin stimulation device.
when I use the loadlibrary command in my Matlab script, I receive these two errors:  "We don't know the Compiler" and "We don't know the ProcessorType architecture"
Which means while reading the "platdefines.h", the Compiler and the ProcessorType does not match the ones listed in ifs.
I have set c++ compiler to visual studio 2015 in Matlab. (also tried MinGW). the system I`m using is Windows 10 (tried on 7, too), 64bit.
I read somewhere that manually defining the ProcessorType and the compiler might solve the issue. But the problem is I Don`t know what they are. (when these two conditions below are not accepted.)
#elif defined(_MSC_VER) || defined(_NI_VC_)
        #define Compiler        kVisualC
#elif defined(_M_X64)
        #define ProcessorType    kX64
How should I find out the ProcessorType and the compiler I have?
I`d be EXTREMELY THANKFUL for any solutions you can think of.
P.S.2 The code seems to work fine on manufacturers system with Matlab 2011. so it may be Matlab-related, but I don`t get how since the error is from platdefines header file.
extcode.h
fundtypes.h
hosttype.h
ILVDataInterface.h
ILVTypeInterface.h
lv_epilog.h
lv_prolog.h
platdefines.h
STIM.aliases
STIM.dll
STIM.h
STIM.ini
STIM.lib
Edited by farzane lk
Share this post
Link to post
Share on other sites
If I had to guess, you'll want to edit STIM.h to include (at the very top, before anything else):
#define _Win64 1 //if 64 bit
#define _Win32 1 //any windows
#define _M_AMD64 100
#define _M_X64 100 // same as above
#define __x86_64__ // and again, this might be the gcc version or something?
#define _MSC_VER 1900 // just a guess, this is ms visual c 2015
The full list of visual c #defines is here at this link, and you can also just go through the NI header file and look for stuff that makes sense.
https://docs.microsoft.com/en-us/cpp/preprocessor/predefined-macros?view=vs-2017
Edited by smithd
Share this post
Link to post
Thank you for the code. The good news is adding these 3 lines you gave me to the platdefine header`s list of "possible values" and editing the If, removed the former errors. YAY!!!
BUT Now I receive a bunch of errors (syntax). With the main error of  "Building STIM_thunk_pcwin64 failed." 😣
Googleing showed that the Matlab compiler is not properly making the "STIM_thunk_pcwin64.dll". There were solutions of changing the dll or the CPP file, which I`m too naive or too overloaded to understand now.
Thanks again
Share this post
Link to post
What is the first error? The exact message could provide valuable clues.
Given that the compiler wasn't auto-detected and that the same files work unmodified on the manufacturer system, I suspect that your compiler hasn't been set up properly.
Note: Visual Studio 2015 doesn't install the C/C++ compiler by default; you must explicitly select it during installation. Can you verify that you have a working C/C++ compiler on your PC?
Share this post
Link to post
My understanding from what came up is that Matlab is attempting to build a wrapper dll with some more matlab friendly interface. A quick google didn't find me anything about how it does this, but that seems to be what its doing. I say that because the "we dont know the..." come from the labview headers. So it seems like Matlab is running a compiler against stim.h which includes the platdefines header, and since I'm assuming the matlab compiler is not one of the ones NI was expecting when they built this (or if matlab simply doesn't #define the same definitions NI is expecting), the compiler correctly spits out the errors shown, as in this snippet of platdefines:
	#ifdef _M_PPC
		#define ProcessorType	kPPC
	#elif defined(_M_IX86)
		#define ProcessorType	kX86
	#elif defined(_M_ALPHA)
		#define ProcessorType	kDECAlpha
	#elif Compiler == kBorlandC
	#elif defined(_ARM_)
		#define ProcessorType 	kARM
	#else
		#error "We don't know the ProcessorType architecture"
	#endif
So the question becomes what should it be. My guess is that they should be defined per the labview exe/dll which is why I suggested the MSVC compiler definitions (as I understand it, this is what NI uses for windows builds). However it may be that the right answer is to edit the headers to set something more appropriate. For example, in the section above, you could comment every line out except for "#define ProcessorType    kX64". Similarly you could comment out the compiler section and replace it with "#define Compiler kGCC" (if that is what matlab uses, which I assume it is). The only reason these need to be defined is so that extcode.h picks up all the appropriate definitions and headers for the platform. For example. stim.h uses the type "uint32_t". This is defined in stdint.h, but if your compiler isn't including it already then stim.h can't be compiled. So, in fundtypes.h, it has a bunch of platform checks to see if it needs to define those types.
The easier route, vs trying to make extcode.h have the proper types, would be to just edit stim.h directly to include the type definitions you need. I would suggest editing your stim.h to look like this (lines 1-7):
//#include "extcode.h"
//this dll only uses two uncertainly defined types, but they are defined by stdint.h. This section is borrowed from fundtypes.h
#if !defined(_STDINT_H_) && !defined(_STDINT_H) && !defined(_STDINT)
	#include <stdint.h>
  	//alternatively comment the line above and uncomment these lines:
	//typedef int             int32_t;
	//typedef unsigned int    uint32_t;
#endif
#ifdef __cplusplus
extern "C" {
#endif
Edited by smithd
Share this post
Link to post
I attached the error I get.
and about the visual studio, yes I had reinstalled and selected the option. and it is selected in Matlab.
Share this post
Link to post
1
Hi again, sorry for the late reply.
Thanks for the guidance.
I tried editing the STIM.h and the error didn`t disappear. it is still: "Error using loadlibrary" "Building STIM_thunk_pcwin64 failed."
but now the error refers to the "oncleanup" function, that is called for ending a function.
I have attached the oncleanup.m and the error I`m getting. (its location was in matlab\toolbox\matlab\general\).
Seeing the error, it made me wonder if anything would change if I actually connect the device. (till now I was just trying to make the "loadlibrary" command work.)
onCleanup.m
Share this post
Link to post
Your screenshots reveal the main problem: MATLAB is using an Perl script with regex to parse your header and generate its "thunk" code. Unfortunately, this script can't understand your header because it does not understand all C. (Your header uses "complicated" C)
It says, "Unescaped left brace in regex is deprecated here (and will be fatal in Perl 5.30)". "Deprecated" means the functionality is old, and no longer encouraged. "Fatal" means the functionality is completely broken. And we can see that it is very broken indeed, because generated this line which is not valid C code:
EXPORT_EXTERN_C uint32_T(__cdecl__))OPEN_USB(voidThunk(void fcn(),const char *callstack,int stacksize)
It sounds to me like the Perl script worked fine on the older MATLAB 2011, but is broken by an incompatible upgrade in MATLAB 2018. I'd say that the fastest way to reach your goal is to downgrade MATLAB. (You might be able to get away with downgrading the copy of Perl that MATLAB uses, but I'm not sure if this is possible)
Side note: I also noticed that MATLAB is using GCC, not Visual Studio -- Look closely, and you'll see the compiler path: C:\TDM-GCC-64\bin\gcc. This means, even though you've told it to use Visual Studio, it's still using GCC.
Edited by JKSH
Share this post
Link to post
Yeah I looked again, I don't think matlab can use visual studio.
Nah this is a parsing problem.
Maybe I'm misreading the error but it looks like it doesn't know what __cdecl is -- __cdecl is visual studio specific. Since I think most compilers use that calling convention by default, you can safely remove all instances of __cdecl from stim.h
Share this post
Link to post
Not directly related to dlls generated specifically by labview, but I happen to have also been dealing a lot with matlab loadlibrary on third part shared libraries during the last days, so I allow me the liberty of adding some comments. If that is not clear enough, let me stress: for loadlibrary to work, the matlab build chain has to generate this _thunk_ file, and it will succeed at it only if all is in place. Looking up "cannot build"  on the internet is bound to bring up irrelevant HELP ME  HELP ME posts; my winning strategy for importing was to start tackling the compilation errors from the first onward.
It should be clear that loadlibrary speaks only C, not C++. The perl parser does quite a good job on well written C headers, but does not handle everything (see, in matlab, help on "Limitations to Shared Library Support"); for one, it does not deal with unions and non typedef'd enums. The perl "deprecated unescaped left bracket" warning I got too, and for me it was merely a symptom, not the cause. When you've got .h files, check for anything which stinks of C++. If the .h file is really well written, it will have proper #defines which reduce the prototype syntax to something digestible by pure C. For example, defining EXPORT_EXTERN_C to be an empty string if not __cplusplus. If that is not, you may get through by pointing loadlibrary to your massaged version of the original header files. That is what I ended up doing in my current project, and fortunately involved only minor changes in them.
Matlab should be perfectly able to use visual studio afaik, but alas, there is a certain third party library which I managed to import rather easily in linux with gcc, whereas the corresponding windows version of it - well, I haven't even started to bugger about what VS wants from my life there (I might have to, soon... 😒)
Another strategy can be to interface with matlab by writing mex files. Mex files can be C++ (don't look at me I'm analphabet there).
Edited by ensegre
Share this post
Link to post
Ah yeah I read a note that said a specific visual studio version was no longer supported, should have scrolled down further.
Share this post
Link to post
  • Similar Content
    • By Fil_Lab
      Good morning. I'm new of labview and I would like to call C++ code from VI for my application.
      I did a
      C++ project, generate DLL and I call it from VI. It's working on my pc but if I make an application for another pc, the application works but the dll is not working. I installed the c++ redistributable on second pc but I had the same problem.
      in particular a message error with "error 42" appears. Can you suggest me some check to fix it ?
      thank you very much for your collaboration
    • By Argold
      I'm writing an application where users can plug in their own matlab code via a Mathscript "wrapper".  I need a way of timing out the matlab in case the user creates an infinite loop.
      Does anyone know if mathscript provides a native timeout (google didn't find anything when searching "mathscript timeout").
      If not, does anyone have any good (hopefully simple) suggestions?
      Thanks!
    • By Manudelavega
      Dear all,
      My company is starting a project where some Matlab files (.m) need to be executed by LabVIEW. The 2 obvious solutions are Matlab script nodes and MathScript nodes. Unfortunately, even though the latter one is the most cost-effective and light in terms of installation, many of the functions we need are not supported by the Run Time Engine, so it's kind of a deal breaker.
      For the Matlab script nodes, I know Matlab needs to be installed since LabVIEW will request Matlab to execute the scripts through ActiveX. What I don't know is: what version of Matlab? Is there a cheaper "Run Time Engine" of Matlab we can use instead of buying the full-blown developement version of Matlab?
      Any other comment, remark, suggestion, alternatives?
      Thanks!
    • By Stobber
      I was mucking around in General Error Handler.vi today and noticed a weird subVI with a really intersting comment inside. Thought I'd share it with the crowd, since it applies to time-critical processes, thead swapping, and general compiler insights.
    • By doofus_au
      I am new to labview and need some assistance trying to open a .mat file for further analysis (example file attached). The file formate is level 5 and I believe the data is in arrays. I do not have access to confirm the structure but have been told the layout of the data i need to access follows the following structure: MotionFile_walkaround -> Actor_50_human -> Segments -> Sacrum -> Pose.
      I have successfully read the header and found that byte swapping is required. I have downloaded the Mat-File IO library but have had no success in reading the actual data set beyond the header but assume this is due to my inexperience with both .mat files and labview.
      Any help would be greatly appreciated.
      walkaround.zip
