Hex Strings are kicking my A$$
I'm trying to build a Hex String to send to a piece of equipment... As you can tell by the title... Hex Strings are not my favorite things to work with...
The correct output from this vi should be a hex string 0106 012C 05DC 4B36. I don't have a clue where I'm going wrong.
Can someone point me in the right direction??? Please....
crc16-2.vi Setpt to String.vi
You are mixing definitions of "Hex String".  It appears you need a raw/binary/flat data string.  So replace the Number To Hexidecimal String with a Flatten Into String.  The Number To Hex String converts into an ASCII text, which you do not want.  Further, since you only want 4 hex character (ie 2 bytes), you need to add a U16 conversion bullet after the multiplication.
Edited by crossrulz
