Call Library Function Node: Library not found or failed to load
Recently I've installed the OpenG Toolkit v4.0.1.9 on LabVIEW 2018 x64 on Windows 8.1 through the VIPM. When I try to use it, namely ZLIB Inflate / Deflate Vis, I get an error saying "SubVI 'ZLIB Inflate__ogtk.vi': SubVI is not executable". When I open it and select Configure... on Call Library Function node in a Library name or path field I see "C:\Work\OpenG\opengtoolkit\lvzip\source\lvzlib.*".
The same thing with Vis referencing ogportio.dll.
Am I supposed to update them manually before first using them? I didn't find any info about this problem.
Edit: Ok, when I try to update it LabVIEW says it's not 64-bit compatible... Any progress in this direction since 2010?
Edited by EvgenKo423
There is also a version 4.2 in the works with more 64-bit support - as discussed here:
On a side note; I used version 4.1 now from LabVIEW 2019 on a Linux RT for ARM target and got build errors that I do not get in 2018.
I have not investigated it much yet though so it might just be a local phenomenon:
From the build log:
Deploying ZLIB Open Read File__ogtk.viZLIB Open Read File__ogtk.vi loaded with errors on the target and was closed.
LabVIEW: (Hex 0x627) The function name for the lvzlib.*:lvzip_unzOpenCurrentFile3:C             node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
LabVIEW: (Hex 0x627) The function name for the lvzlib.*:lvzip_unzOpenCurrentFile2:C             node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
From the build log:
Are you sure you installed the OpenG ZIP Library 4.1 on that RT target after you updated the LabVIEW version on it? Pending this issue I should be able to have a test package ready sometimes this week which is supposed to support Windows, MacOSX and Linux (all 32-bit and 64-bit), NI Linux RT (ARM and x64) ready. Support for the VxWorks and Pharlap RT targets will be available but not tested.
Edited by Rolf Kalbermatter
