Hello,
I m having difficulties with Lava JSON API lib. I'm not good at Labview but if you can help me. I don't see a documentation or a small exemple.
My REST API return me this kind of string :
        "id": "Cartographie",
        "records": [
            "20190801-162634"
        "name": "Cartographie",
        "description": "",
        "lft": 1,
        "rght": 2,
        "tree_id": 3,
        "level": 0,
        "parent": null
        "id": "Cyclage endurance",
        "records": [
            "20190909-140001",
            "20190703-100000",
            "20190603-110704"
        "name": "Cyclage endurance",
        "description": "Some descriptions",
        "lft": 1,
        "rght": 2,
        "tree_id": 4,
        "level": 0,
        "parent": null
I need to make an array of ids or names.
How would you do that easily ?
Oops, two things called "name".  The "Names" output is an array of item names.  Your item name is, confusingly, "name".  "Cartographie" is one of your date values.  It is a string, and I in my example provided a string as the data type.  But you provided as data type an empty/void Variant, which will fail.  Use a string like in my example.
