Moving a terminal out of a case structure
I might be able to post an example of this for further understanding, but for now...
I have a template with some case structures where I am instantiating a typedef control. When the control gets created it gets placed inside one of the case structures. I actually would like it to be outside of that structure so it can be used as the selection terminal control ("?").
I have found a workaround by just adding a control to the template and then replacing it with the new control (so it's already in the right place and wired properly)... however I was still wondering if there was a known way to solve the above problem.
