N Dimensional array to 1d Array
pawhan11
I am looking for a way to do convert N dimensional array to 1d array of variants. Can this be done using native labview functions (some hidden gems etc), without using OpenG?
Another issue is with maps and sets, i want to get data out as array of variants, having set or map as variant.
18 hours ago, pawhan11 said:
For arrays i came up with this, dimensions are handled up to 10
14 hours ago, pawhan11 said:
Nice, but I require the input to be variant, not an array.
¯\_(ツ)_/¯
Edited by ShaunR
@ShaunR I might have formulated question incorrectly 😁 I want 3 separate functions that have:
- variant input and return 1d array of variants when input variant is array  (any dimension any data type in array)
- variant input and return array of variants when input variant is  set (any data type in set)
-variant input and return variant pairs of key values when input is Map (any data type of key and value in map)
For Maps and Sets I can get type info using Type Parsing Library but not the actual, the only way i see is digging into type descriptors...
There is a VI in OpenG LabVIEW Data Library that does this for you.
I took this as a challenge and added two VIs to my library on GitHub - https://github.com/LogMANOriginal/LabVIEW-Composition
Decompose Map extracts variant keys and values of variant maps
Decompose Set extracts variant elements of variant sets
I have successfully tested these VIs with various different types, but there could still be bugs. Let me know if you find anything. I strongly discourage using these in production!
Edited by LogMAN
Fix image scaling
  • Thanks 1
