[CR] Y Controls Support - Version 2.0.2.0 Installer.zip
  • 4 weeks later...
I've discovered a bug.  It appears to be a bug in LabVIEW.  Here is what I believe is happening: Hiding inside each instance of a Y Control is an instance of "C: ... \LabVIEW xxxx\resource\plugins\Y Control\Ability Manager\Y Control Ability Manager.XCTL".  When LabVIEW loads an instance of a Y Control that depends* upon another Y Control, there are 2 instances of "Y Control Ability Manager.XCTL" that need to be initialized: One for the outer Y Control and one for the inner Y Control.  The "Init" ability of the Xctl for the inner Y Control gets called first, and it works OK. However when the "Init" ability is called for the outer Y Control, it is passed the wrong refnum: Instead of getting the refnum to the instance of the Xctl in the outer Y Control, it gets a refnum to the instance of the Xctl in the inner Y Control.
*In my case this happens because I have a Y Control calls a dialog VI that contains a reference to a VI that has a Y Control.
After a lot of digging, I found the bug (in my code).  It wasn't happening just when one Y Control depended on another, but whenever two different types of Y Control were both in memory.
The fix is attached.  I've also done a bit of cleanup (including closing a dangling VI ref), and some minor improvements of the help.  It's backward compatible; no need to rebuild anything, just run the new installer.
Y Controls - Version 2.0.3.0 Source.zip Y Controls Support - Version 2.0.3.0 Installer.zip
  • 7 months later...
When I click "Go" on the YControl wizard, LabVIEW just sits there seemingly forever, all the while logging this error every second:
<DEBUG_OUTPUT>
01/27/22 11:52:33.767 PM
DWarn 0xFCC058F4: An item recompiled in the final iteration should not still have recompile needed set: [VI "Y Control Isolators and Misc.lvlib:Insert Info In Error.vim" (0x000000000a5b12a0)]
/builds/labview/2021/source/compiler/compiler.cpp(643) : DWarn 0xFCC058F4: An item recompiled in the final iteration should not still have recompile needed set: [VI "Y Control Isolators and Misc.lvlib:Insert Info In Error.vim" (0x000000000a5b12a0)]
[ExecSys:0; NOT InExec]
</DEBUG_OUTPUT>
0x00000000006D9611 - <unknown> + 0
0x00007FFFF6DDB5F5 - _ZNK11DebugStream7ProcessEv + 25
0x000000000064D329 - <unknown> + 0
0x000000000064D991 - <unknown> + 0
0x000000000064E1B8 - <unknown> + 0
0x0000000001D14136 - <unknown> + 0
0x0000000001D15369 - <unknown> + 0
0x0000000001D18333 - <unknown> + 0
0x0000000001D1AC85 - <unknown> + 0
0x0000000001DB393D - <unknown> + 0
0x0000000002032563 - WSendEvent + 253
0x00000000020339A4 - <unknown> + 0
0x0000000001F6BABD - <unknown> + 0
0x0000000001F658F8 - <unknown> + 0
0x0000000000608599 - <unknown> + 0
0x00000000006087A8 - <unknown> + 0
0x00007FFFF6802B25 - __libc_start_main + D5
0x00000000006069F9 - <unknown> + 0
I'm using LabVIEW 2021 Community Edition on Linux.
  • 5 months later...
Y Controls - Version 2.0.3.0 Source.zip 1.97 MB · 9 downloads Y Controls Support - Version 2.0.3.0 Installer.zip 1.79 MB · 8 downloads
If I open the content of the "Installer.zip" file, it appears to be missing the "Install Y Control Support.vi", "UNInstall Y Control Support.vi" and "Installer READ ME.txt" that you had in the 1.x version in that thread.
If I copy those items in the Pure G Installer version 2 and run install, things seem to work fine.
For some reason, the help file is showing a TOC but the content appears blank (same for version 1 BTW, so it might be something related to my installation in LV 2021 SP1 64 bit/Windows 10).
Edited by X___
