Build a Road to Space! Two LabVIEW dev positions open at Blue Origin
Our team is responsible for the design, implementation, testing, deployment, and maintenance of LabVIEW based data acquisition and controls systems that support rocket engine test stands, component testing and ground support equipment. You will share in the team’s impact on all aspects of component, vehicle subsystem, and engine testing. This position will directly impact the history of space exploration and will require your dedicated commitment and detailed attention towards safe and repeatable spaceflight.
Do you love OOP, actor-framwork and real-time systems?  If so this is your team.
Position is for the Kent Washington office.  Must be a U.S. citizen or national, U.S. permanent resident (current Green Card holder), or lawfully admitted into the U.S. as a refugee or granted asylum.
https://blueorigin.wd5.myworkdayjobs.com/BlueOrigin/job/Kent-WA/LabVIEW-Software-Engineer-III_R9520
https://blueorigin.wd5.myworkdayjobs.com/BlueOrigin/job/Kent-WA/LabVIEW-Software-Engineer-III_R9521-1
