how to send 2d array into 1d array?
wyyew
Yes it is possible.
This method used the Reshape Array in the array pallet.
I can't remember if ver 5.1 had this fucntion in it if not you could change the 2d array by using a for loop
Version 5.1.1 definitely has this function. I've found it very useful for depicting the range of values seen in a 2d array (for instance, an image) into a 1d waveform graph, for the purposes of quickly illuminating to the user where the background level sits and whether saturation is occurring.
-Pete Liiva
