GUI with Multiple Dialogs
rajath
i want to develop GUI with multiple dialogs which i want to call from main window like subroutine
with out closing the main window
You might want to consider "subpanels" within the main VI.
(Help --> Find Examples --> Search --> subpanels)
Another way is to make use of the "tab control" to produce a paged front panel on your main VI.
Just place a sub-vi on the diagram. Then go to the sub-VI's properties and set: Open panel when called, AND close afterwards if originaly closed.
I tried like that and i am able to transfer the control from one window to other
but i am not able to close the window after transfering the control
post-3322-1130330158.jpg?width=400
Look under the examples:
C:\Program Files\National Instruments\LabVIEW 7.1\examples\general\menubars.llb
There are several applicable demos there. Also in the same directory look for the uievents.llb which has a bunch of deoms and techniques you should become familiar with. There is an example in ther for using menu items with events.
enjoy :-)
