Transperant label
RaviPaike
Select the label, select the color tool, right click on the label and in the color box select the " T " for transparent. No border, no background color. If you want you can then select the text tool, highlight/select the text in the label and go to the Text Settings menu >> Color and in the color box set the text color so that it is just barely visible, or even invisible for that matter. You can later select the text to see the letters.
