LV 8 Application Debugging
Hi All,
I have built an EXE with debugging enabled. I run the EXE, it opens up unstarted. Then in LV's project explorer I go to Operate>Debug Application...
When I attempt to connect to me EXE I get an error message as shown in the included image.
Anyone have any thoughts?
How can there be an incompatibility with the debug protocol? All this is being done on the same PC.
Any help is appreciated
post-1881-1136313659.jpg?width=400
Hi All,
Don't you need to enable the TCP/IP access for VI Server of the executable application in order for the debug connection to succeed? The error message itself is quite likely not very accurate but something is going wrong.
