Front Panel Resize bug
molsen
Programmatically opening a VI in edit mode followed by run mode fails in LV8.0. (Works OK in LV 7.1.1)
If the called VI (SubVI.vi) has the property 'Window Run-time Position' set to:
- Centered
- Use Current panel size
Closing the VI reference puts the VI in the upper left corner with a size of zero !!!!!!
(Setting the 'Window Run-time Position' to 'Unchanged' everything works fine - but then the VI is not centered).
I have attached two VIs (Main vi calling a subvi) that shows the problem.
(It must have something to do with the way the reference is opened or closed because if the type specifier is connected to both open functions it seems to work).
(Has been reported to NI).
Download File:post-43-1137077600.zip
