Limit to decoration size (curiosity)
Just discovered that if you take any decoration and stretch it. It will only allow you to stretch it to a size of 4095x4095 pixels. This is is LV7.11. This is not a show stopper but was curious why?
4096/256=16 bytes which might be a limitation in supporting a wide array of hardware and OS. Although it's odd because scrolling isn't anything new.
http://www.displaymate.com/infodmm.html
That isn't an answer but it might be something to do with the OS support. I wonder if this is the same limitation in LV8.
hmm ... i wonder why someone needs decorations lager than a screen size? who wants to programm those wallpapers?
if i suggest, that jim has allready bought his 30 inch dell LCD ;) he would only need 2560x1600 :question:
i can understand that sometimes you need lots of space in the BlockDiagram, but on the Frontpanel ?
