General Code
meocop
Hello,
In my application, I have two xy graphs, one for the North and the other for the South. So depending on what the user input is (N or S), I want to plot the information on the correspondent graph. I used Match True/False string to capture the user input, then use a Case structure to pass my information to the correspondent graph. I does not work. Please see my attached VI and help!!!
Download File:post-4960-1159977483.vi
Hello,
A cursory look at your VI tells me that the Case Structure has the same outputs in both the cases. That would not work.
-Khalid
Hello,
Your graph will display data if you turn on autoscaling for the y axis.
You haven't really stated the problem so I can understand it, the example code is a big mess with no effort made to document it, or make it neat for reading. Also, it sounds a like like school work. For those reasons I am not going to be very specific with my help. If you make it hard for us to even read the code or understand its goals then it is much less likely you will get useful advise.
Please understand that good advise actually takes work to think up and present. You should be willing to work fairly hard in order to get hard work from us. If you have worked hard I can not tell. It just looks like a big sloppy mess. Sending us code is a good first step, but it needs to be quality work to the best of your ability. An extreme minimum of effort on your part is that we should not have to move icons around just to see where your wires go. Your code is unreadable.
Consider this methodology:
Take the problem one step at a time.
First generate good data. And check the data before moving on to the next step. There is no point in trying to graph nonsense. You give no clues as to what the data should look like so I can't guess if it is the generation of it that is a problem or the display.
I suggest you place probes or indicators much earlier in the dataflow so you can see if you are doing anything like what is needed. Or scrap the whole vi and start over with simples steps.
Mike
Mike
Mike,
- You're absolutely right that my code is a mess and unreadable
- You're wrong that this is school/course work
Attached is a simplified version. Basically depending on the user input (N or S), I want to plot on the Norht or South graph. I have two analog signals, one used for x and one for y. I use 2 RG in their places in the code. Where I am stuck is in the False case, I don't know how to wire. Your help is appreciated.
Meocop
Download File:post-4960-1159988801.vi
Mike,
Meocop
I see Christopher has given you some help.
I did have one idea you might like to know about. You can tag your North and South data when you collect it by clustering it with a boolean where N = 0 and S = 1. Then when you need it you unbundle the boolean to pick the case you want. You are not limited to booleans and only two potentials, you can bundle an enum with unlimited choices instead, and therefore unlimited case selections. Clustering is useful whenever you want two unlike but related pieces of information to travel together.
Mike
Re- attach the test.vi
MC
Check out the VI again. That's my solution to my problem. The code is horrible, but it does the job. Pleae share a better way of doing this if you think up one.
Make sure you use capital N or S.
Thank you,
MC
I think the concepts you need are Shift Registers and Enabling Indexing of loops. Take a look at the example attached. The Shift Registers allow you to watch the data build. Enabling indexing puts the same collection of data on the output border of the loop for display when the vi is stopped.
Both functions are accessed by right clicking the loop border.
I threw in an initalization sequence frame that runs as soon as the vi is started to clear the graphs and to reseet the stop button.
Mike
Download File:post-48-1160014207.vi
Mike
Mike
Thank you all for helping me. You guys are great!!!
MeoCop
Admin Note: This is a great example of how to participate on the LAVA Forums! :thumbup:
Crelf and Mike,
What I want to do is to to take a bunch of data points on my N part and then a bunch of points on my S part, then calculate some statistical vaules such as max and min. So I used the Enabling Index concept and it seemed to work. However I kept getting 0 for the min and I am not sure why. Please help.
Meo Cop
Download File:post-4960-1161363802.vi
Crelf and Mike,
Meo Cop
Try something like this
Dan
Download File:post-114-1161366024.vi
Dan
Thank you Dan, but I don't think your program works the way I want it. The max and min results did not look right because they were greater than 1. The RNG should give numbers between 0-1.
Also I've written my program in such a way that using Enabling Index is the most simplest way and I like to make it work that way.
Thank you.
MC
Expand the indicator so you can see the whole number. You'll see that there's a E-x hidden there.
Edit:
The advantage of doing it with the shift registers the way that Dan did is that it allows you to monitor (via plotting, probing, or statistics) your arrays as they are built. This helps quite a bit in debugging. It will, however, result in a performance hit if your arrays grow to be very large.
Gary
Absolutely! The question is clear, the asker has already tried some stuff, and provided an example - and look at the results! People have really tried to help out :) Maybe we should link to this thread from a FAQ - how to ask a question...
Crelf, I don't know if you're being serious or not, but since I got chewed out by Mike for showing a messy VI, I've tried to ask simple questions and given clear examples. These simple things play big role in an application I am trying to develop. See, I write C++ and Java, so my boss thinks that I can write Labview and that's why I am assigned with some labview projects and not sent to any training course. So I appreciate any help I can get.
Dan, sorry for falsely accusing your VI not working. But I still think the Enabling Index will work better for me if I can make it work.
MC
I am completely serious - we've had a spate of threads where new users ask vague questions and/or expect everyone else to do the work for them without lifting a finger themselves. I agree with Mike: your post was refreshing and I really appreciate it! :thumbup:
