prowler97
Hi Ladies & Gents;
I need a little help. I have a strain gage .vi program but I need to change/add two things:
1) Filter. I need an adjustable filter to filter out low frequency noise.
2) How do I zero out my gages? One gage reads .0012 and the other reads .0004 when nothing is turned on. How di0 I reset/calibrate them to zero?
Program Attached below.
Labview 8.0
Thanks for any help you can provide. I am new to labview, but quickly learning.
Download File:post-6432-1160354015.vi
Hi Ladies & Gents;
Labview 8.0
1) Look into the function palette-->Signal processing-->Waveform conditionning
2) One of the simple ways would be to acquire the data once before looping and substracting the values in your loop.
Here's a hint. You don't have to loop through an arrray to do simple arithmetic - just use the arithmetic functions they will operate on arrays using a scalar input.
Mike
