In FPGA module, arrays have an option to "Set Dimension Size..." when you right-click on them in the front panel.
This brings up a "Set the size of this data item" dialog box. Here you can select fixed or bounded array size and elements.
I decide to copy this array and place it into a regular Labview VI to see if it would work, which it did. Then, I wanted to see what would happen if I tried to insert 1 element into a fixed array [16]. The output wire of the insert into array becam
