Adding a tunnel to a case structure
Chris Davis
I'm working on a new scripting example / tool to create a Functional Global with the user's choice of control. To create this subVI from scratch I have to create a case structure inside a single run while loop. No problems so far. I've even added the ability to pick a control from disk and add it to this new VI. The problem I'm having so far is creating a tunnel for my control from disk to pass its value thru. Any ideas on which methods will allow me to add a tunnel to a case structure?
I'll be posting this example / tool to the CR when / if I get done with it.
BTW, I'm trying to get all this in LV7.0 but I also have access to 7.1.1 if it has the solution.
Thanks
Chris
EDIT: guess I should have looked a little harder, I found it. Simply use a "Connect Wire" method with the terminal of your choice and voila!
