LabVIEW stops on DLL when closing a LV8.0.1 window
tnt
Hi all,
I've made a DLL-wrapper (using MS Visual Studio 6) to make a suppliers dll callable from within LV.
The original DLL contained some functions which returned a struct and unfortunately
LV only supports Void, Numeric and String as returnvalue.
I have a polling loop which continuously reads data from the dll
(this loop runs for several hours w/o any problem, NO stops and NO memoryleaks).
When I go to the block-diagram and add a probe to the block diagram, the DLL crashes (see attachment)
post-2311-1166445801.png?width=400
The location of the probe on the block-diagram makes no difference,
even closing an unreacheable probe causes the same effect.
EDIT1: closing a probe that is placed on a non-running VI causes the same errormessage
EDIT2: opening a new vi and closing it again also generates this errormessage,
so closing a LV-owned window causes the DLL-call to stop
Does anyone has seen this behaviour before and/or knows how this can be caused?
Thanks,
TNT
Update...
it seemed that closing a LabVIEW "window"/ "function pallette" / "help window" generated a Microsoft C++ exception in the DLL :thumbdown: .
The only work-around that worked was by adding a try {} catch(...) {} (in my wrapper-DLL) around each call to the suppliers DLL.
I just can't figure out how such things can happen, my wrapper is farly straight-forward and
using the suppliers-DLL directly from LabVIEW (the useable functions), I have no problems either...
Another strange things was that when I placed an "unhandled exception" MessageBox in the catch(...),
it became even impossible to close a LabVIEW window, the Messagebox "unhandled exception" popped up but the window remained open.
I know this a LV-forum :thumbup: , but are there perhaps any VS6-programmers out there who know how to get the thrown exception in a Catch (...)??
Thanks, tnt
