Simple HTTP request
encryption
In standard labview I could use the http control but I need to learn how to do this with the basic TCP tools provide with the PDA module.
Thanks!
Nick Powers
I am working on a labview mobile 5.0 application using labview 8.2 and I need to be able to submit a URL to a web server and then retrieve the data in a string. I plan on using match pattern on the retrieved data after I have received the HTML data.
Thanks for any help you can provide!
Thanks,
Nick Powers
Hi Nick, and welcome to LAVA! What you're asking for isn't really a LabVIEW question per se, but more a tcp / HTTP question. LabVIEW can perform whatever tcp messaging you like, so try a google on terms like "get" "html" "tcp" etc...
Nick,
There is an unreleased http library in the OpenG CVS repository which uses TCP-IP to perform an HTTP GET.
Info on how to do a CVS checkout:
http://sourceforge.net/cvs/?group_id=52435
Browse CVS Repository (ViewCVS):
http://opengtoolkit.cvs.sourceforge.net/op.../http/http.llb/
The http library depends on some other OpenG libraries, so you should install VI Package Manager in order to download+install the OpenG libraries.
-Jim
