variant data type
Hello everybody,
I don't use variant data type because I haven't got information about it and I don't know when, how and why use this kind of data type. So, can anybody say me something about the use of variant.
Thanks.
Here is a document that has some info on variants:
http://www.openg.org/docs/LabVIEW%20Data%2...01%20of%202.pdf
There is plenty of information about variant data type in LabVIEW help, you should read that trough the help files. As a summary variant data type is a datatype that can hold any other LabVIEW data type. So you can convert any LabVIEW data to variant and then back again. The benefit is (if you consider it a benefit) that you can by-pass strict compile time type checks and perform the type checks at run time. The drawback is exactly the same thing.
LabVIEW 8.20 is a object oriented programming language (LV 8.0.1 is not) and you can do many things with LV classes more safely that you would need to use variants otherwise.
