compacting a ms access database with labview
Hello there,
I'm trying to find a way to compact a database with labview. I've look for an ms access 2003 activex, but I didn't find it. Does some know how to do it?
Thank you,
coolaid
Here's a screenshot of a VI that performs the compacting. Basically you have to manually create the temp file and then replace the original by deleting it and renaming the temp.
post-987-1169139109.png?width=400
Thank you guys, that solve my problem!
just one other thing, what are you VI Data Act? Are those VI that you created? If not, where can I find them?
Thank you,
The screen shot that I posted above was from an application that we developed that made extensive use of the MS Jet Engine. One of the more powerful features is the built in replication. The screen shot below shows some of the other utilities that we used.
post-987-1169177759.png?width=400
And no it isn't possible to upload these VIs since they are currently part of a much larger application
