QUOTE(spacetoon34 @ Mar 12 2007, 08:20 PM)
Hello,
I want to ask how can I generate multi GUI in my program and how can i make a main GUI and sub main that can i transfer to it by clicking a button .
Thanks
For data transfer you can use:
globals
functional globals
notifiers
user events
queues
look help for it.
Eugen
QUOTE(spacetoon34 @ Mar 13 2007, 12:20 AM)
I want to design a main panel with button which every one open a different file.vi and i want to ask how can i size my panel such that the user saw the tools when execution without apperence of empty region.???
Are you trying to embed the subVI's panel into the main VI or are just looking for a pop-up window?
If it's the pop-up, size your VI's window to the size you want.
If it's embedded, you'll use the entire size of your subpanel, you could change the height and width of your subpanel based on the height and width of the subVI you're opening, and then re-size your main VI's window from that... but it would be much easier to use a pop-up subVI instead of this.
