Saving VI settings to a file
Of the multitude of ways to save "settings" to a file, what is your preferred method? Keys (ini), Datalog, Spreadsheet, pure text, etc... they all have drawbacks. Typically, I need to save numeric and string and boolean data - flat or structured, 3 things to 50 or more. The "keys" method gets HUGE (real estate), although the resulting file is elegant. Datalog is simple - just bundle the stuff up and send it on - but the file is unreadable (by eyes) and making changes to the data types in the VI mandates changes to the "file writer" VI. Spreadsheet String to File needs to have numbers converted, then back again.
Any tips? :throwpc:
QUOTE(PJM_labview @ Mar 18 2007, 01:41 PM)
I just tried some of this stuff. While it's probably the bee's knees, I can't get it to work. The file is always empty. I probably don't fully understand what they mean by "section cluster". Any examples out there?
-Richard
QUOTE(PJM_labview @ Mar 18 2007, 11:02 PM)
I'm unsure how to read the value back into the controls - the outputs of the read VIs are variant data. I can read one key at a time, but that would take 50 or 60 key reads!
QUOTE(BrokenArrow @ Mar 19 2007, 10:15 AM)
Use the primitive "Variant to Data" and wire your cluster into the type input. You'll get your cluster out with values filled in from your INI file on the output side.
  • 2 months later...
QUOTE(Mike Ashe @ Mar 25 2007, 03:15 AM)
hi All
I had the same problem, and I solved it using a set of sub VI's and XML file... saved the state of every control and restored on open...
check out this Beta LLB for this job :)
QUOTE(GregHicks @ Jun 10 2007, 12:19 AM)
hi All
WOW... 12:19 AM on a Sunday!
Thanks, those are good ideas, if not a bit complicated (lots of VIs). Can you supply a "My VI" with lots of controls (including a cluster or two) showing how to use these VI's?
-Richard
QUOTE(BrokenArrow @ Jun 10 2007, 11:10 PM)
-Richard
Hi Broken Arrow
Yes there are a lot of VI's. The main one is Panel State, just wire that up into the main VI of your application.
There is no reason why the Panel State can't be modified to:
  1. Accept an array of control references
  2. Save Indicators and Arrays
  3. include size to enable a "serial" xml or other output of choice for the application state
Any suggestions are welcome and I will include and upload to the snippets area.
  • 3 weeks later...
Thanks for all the great ideas guys. I wonder, is there any way to make the files not only human-readable but also very user-friendly, for example by putting HTML tags/bookmarks into it so the reader can jump to the parts he considers interesting? Some of my programs have a very large number of settings.
QUOTE(torekp @ Jul 2 2007, 06:46 PM)
You could make them XML or HTML and then use a program like XML Notepad to view and edit them, but it's not worth it. Instead, simply create an options dialog in your program which will be responsible for writing the data to the file. That way, you can split up the options into as many screens as needed (look at the LabVIEW options dialog for an example).
QUOTE(yen @ Jul 2 2007, 11:46 AM)
I'll second that idea. I've tried a lot of different options, but this works the best. I have type def'd controls for the page that the user sees. They're limited to valid entries for everything that I can put limits on.
George
