Documenting Call Library Function Nodes
I have the "pleasure" to try to check and document a set of .dll-wrapper VIs. My main problem is that I need to check the call setups.
Is it possible to programmatically get the "Function Prototype" string displayed in the configure window of a Call Library Function Node?
I tried to print the VI documentation but I only get a picture of the BD. Using an invoke node with the VI-ref, I also only get access to the BD image. I have seen the new display option in the 8.2 Version for names in the connector. But the project is in 8.0.1 :-( . And even with the name display I don´t see the exact call setup like how strings are passed.
Any ideas or hints?
Thx in advance
  • 5 years later...
