Password_Code
Sally
Dear all ,
Still remember my security system ! I have uploaded my code , the user must enter a password to open the door . but now I have 2 show the password in the screen as stars!! How??????????!!!
I do not know how 2 connect multi string with one indicator ! I have tried 2 do local varaible but did not work .
See my code :) I need ur help in displaying stars whenever any button is pressed
QUOTE(Sally @ Apr 30 2007, 04:22 AM)
it will make stars for the string not the numbers!!
Nope - the strings is still there, but only stars are displayed. Try this: drop down a string control with password display turned on, then wire it directly to a string indicator in normal mode (don't change anything). Now type something into the control (you will see an asterisk for each character you type) and then run the VI - voila! The test you typed (but couldn't see) is now in the indicator.
I felt generous today.
I rewrite your VI to do what I think you want (I am far from certain that this is the case though).
http://forums.lavag.org/index.php?act=attach&type=post&id=5666
http://forums.lavag.org/index.php?act=attach&type=post&id=5665
I add quite a few comments that should answer most of your questions.
PJM
http://forums.lavag.org/index.php?act=attach&type=post&id=5664
QUOTE(Sally @ Apr 29 2007, 08:33 PM)
Dear all ,
Hey! see attached Calc2.vi (its simple calculator) Go through its source code you will get an idea for "how 2 connect multi string with one indicator "
Cheers..
Shashi
