Help debug a forums issue
As you know there is a new file upload feature on the forums: The Flash uploader. This allows multiple file uploads to a post at the same time and it also has upload progress bars (very cool). This can be enable in your Settings:
:( However it seems like some of us are having problems with the flash uploader. They get the following error:
I'd like to know the extent of the problem:
- Please enable the flash uploader (if not already enabled)
- Try to upload a small file (a few kb) to this thread using the flash uploader.
- If you have success then that's fine, don't post the reply.
- If you get an error, then post the reply and specify what browser(w\version) and OS you are using.
This topic is now closed to further replies.
