Mount ISO image
QUOTE(h1voltage @ Jun 22 2007, 12:43 PM)
Justin goeres. Just recently added his LVOOP ImageMagick Interface
to the CR.
DESCRIPTION:
This library provides an LVOOP-based interface to the powerful cross-platform ImageMagickt.gif image handling utility suite.
It supports all of the ImageMagick utilities and almost every command-line operator (over 200 of them) with support for custom user-specfied operators for the edge cases.
Several examples are included that demonstrate basic text & image creation, composition, and conversion in and out of LabVIEW (including VI icon creation).
SOLUTION:
I am using IMDISK by Olof Lagerkvist. It works great with the command line and does not need to restart the computer to work. I just dropped it into my project and set the working directory to on the command line to the parent VI's directory. I used the command: imdisk.exe -a -f "C:\file.iso" -m #: . The #: uses the next available letter drive.
Thanks for all the responses!
~Zack
