Setting the window to active
Somehow I expecte the following code to set the VI to be the active window:
http://forums.lavag.org/index.php?act=attach&type=post&id=6302
But the Frontpanel is not the active window.
I set my Front panel to be floating:
http://forums.lavag.org/index.php?act=attach&type=post&id=6303
Does anyone know a solution?
This is all in LV 8.2.1, in LV 8.0.1 it works as expected
See here: forums.lavag.org/index.php?showtopic=8523&pid=32105&st=0&
This might help.
Wolfram
