Import PDF image to labview Front panel
  • 5 years later...
Another way to add a pdf (or maybe another type) to front pannel is:
- Add ActiveX Container on FP
- Right click and SelectActiveX Object
- Enable Create Object from File and Brawse/Select the pdf file (not sure how Link to file works)
Now you have (unfortunately not shrinkable image of the file on the FP. Probably will need to resize the panel etc.
Right click on the image Document/Open to open the actual pdf in the reader.
