New Product announcement - USB 24 channel relay card
EasyDAQ
Greetings Worldwide LV community,
We are pleased to announce the launch today of a new, low cost, general purpose, USB 24 channel relay card.
This card uses simple ASCII/text commands to initialise and control it. Designed to switch either 120/240VAC @ 10 amps, or high sensitivity analogue/digital signals via gold contact signal relays (30V DC@ 1 amp).
We now offer 4, 8, 24 and 48/98 channel USB powered relay card options – all our USB relay cards are code compatible, therefore if you have previously used one of our products, you can easily port your code to another in the range.
LabVIEW, Visual C, Visual Basic, Delphi or Agilent VEE example programs and are aimed at Engineers, Scientists & Academics engaged in the design and development of Test, Automation & Control and Instrumentation/Data Logging applications.
We are Design Engineers and LabVIEW specialists - we regularly use our own products in systems that we design for our customers.
This product, is in stock and, along with all of our USB relay cards, is shipped, Worldwide, free of charge.
From $275/€185/£140.
Tell me more:
http://www.easydaq.biz/PagesUSB/USB24Mx.htm
Regards,
Chris Harden
We design & supply low cost USB & Serial Port Relay Cards, Automation & Control, Data Acquisition & NIDAQ compatible hardware products.
www.easydaq.biz
info@easydaq.biz
We have many connections. Connect with us in 2008.....
