A bug in Labview 7.1?
No.1
Hello, everyone,
I want my user interface window to be maximum, and also want to disable the restore button when I open the vi.
I do that as the attached file.Download File:post-11095-1205976114.bmp
but the result is that the window can also be moved by draging the title bar, and also response once when double click the title bar, and then don't response to that any more.
What can I do to realize the function in Labview 7.1? Thank you.
QUOTE (No.1 @ Mar 19 2008, 08:25 PM)
Hello, everyone,
I do that as the attached file.http://lavag.org/old_files/post-11095-1205976114.bmp'>Download File:post-11095-1205976114.bmp
Although it may not be desirable to you, one way is to hide the title bar, either by setting the "Title Bar Visible" property to false, or by unchecking "Window has title bar" in the VI properties.
QUOTE (Jon Sweeney @ Mar 20 2008, 11:22 PM)
But I want to show the title bar.
Maybe I can do that by the Windows API?
QUOTE (No.1 @ Mar 20 2008, 08:49 PM)
That is not likely possible without intercepting the window message handling function itself. In Windows a window with title bar is in principle always movable. A change in that would require a custom windows message handling function that intercepts the move messages and refuses to operate on them.
Doing that in LabVIEW is quite low level programming and not really possible without an extra DLL that hooks the LabVIEW window message handling function and would intercept the appropriate messages before passing control back to the original LabVIEW window message handling function. All in all a lot of work and complexity to deal with and I would put every possible effort to avoid having to do that in your place.
QUOTE (No.1 @ Mar 19 2008, 06:25 PM)
Hello, everyone,
This works in almost every case.
post-8758-1206114652.png?width=400
Unfortunately you are still able to double click the title bar one time. I think this is a bug. If resizable is set to False then this should not happen. The functionality is sucessfully blocked once the window is small - you are not able to double click again to maximize.
QUOTE (rolfk @ Mar 21 2008, 04:01 AM)
If a window is maximized it should not be movable by dragging the title bar.
QUOTE (TobyD @ Mar 21 2008, 11:06 AM)
And it isn't in LabVIEW either until you make it not maximized. But maximized or not is not the same as resizable or not. And movable is an implicit attribute of non-maximized overlapped windows with title bar unless you customize the windows message handler.
QUOTE (rolfk @ Mar 21 2008, 10:55 AM)
I completely agree. My only point was that a window with a title bar is not "always movable". When the window is maximized it is not movable, so if there were a way to keep the window maximized the problem would be solved.
Toby
