Creating a Sinusodial Signal Generator
Hi Everyone,
I am trying to create a vi, this vi will perfrom the following functions:
1) Set the frequency (1Hz to 1KHz). Default 1 Hz
2) Set the Phase Shift (-180degrees to 180degrees). Default 0degrees
3) Set the Amplitude (0 to 20). Default 1
4) Set the Offset (-5 to 5) Default 0
5) Set the number of samples per cycle (20 to 1000). Default 100.
6) Set the number of waves (1to 50) Default 1
7) Set the start time t0 Default.
I am new to Labview I have look at tutorials in creating a analogue waveform vi, but the Sinusodial is a bit more involved.
Can you assist.
hi , I have made a bf generator it works but it is not super fine programmation. I can give you the code if you need it. Jason
QUOTE (MBeckford @ Mar 31 2008, 11:15 AM)
Hi Everyone,
Can you assist.
