Executable Application Close Effect
post-10325-1213851869.png?width=400
Question: When I close a VI with the Window Close method what actually happens in the background?
It seems that the VI front panel closes but the VI is still running even if I handle application close event.
It doesn't finish off it code?
I did a search so I know for an Executable I get handle this for the top level VI by tweaking the .ini to do a cleaner shutdown.
And EyesOnVis talks about execution relative to top level vi in code.
Cheers
JG
Even better is to use the "Panel Close?" notification event. Then you can discard the user's panel close request and perform a controlled shutdown of your program, ensuring that you can run any cleanup subVI's that you require. I actually do this for both the "Panel Close?" and "Application Close?" notification events, so that I can always ensure a proper shutdown.
