Got locked out from my VI!
Hi there,
Got some stupid problem (I locked myself out from my VI), which I´m trying to fix for some time already. But nothing works!
What I wanted to do:
- Make a program, which starts automaticly on a double-click in Windows(-Explorer). And when the user presses the "END" button it closes.
What I did:
- I set the front panel appearance as "Dialog" in the VI settings (stops or interupts by the user are no allowed).
- I put an "END-Labview"-box at the end of the program (that it closes, when the "END" button is pressed).
What the program does:
- Exactly what it should (opens, runs and finishes after "END").
- But I don´t get into the block diagram anymore to make changes.
- I tryed to stop it by provoking errors, but it just crashes.
- Also breaks in SubVIs don´t let me interupt the main VI.
- I tried hot keys (Ctrl+., Ctrl+E, Ctrl+C etc.).
- I tried starting it in Windows-Explorer holding down Shift, Alt or Ctrl (this works with some other application).
Question:
- Is there some way to get into the block diagram, or is it lost and I can redo the whole VI???
Thanks for any helping replay in advance!
