error building labview app with excel toolkit
I haven't seen that error, but did you make sure to include the "...\vil.ib\addons\_office\_exclsub.llb\_Excel Dynamic VIs.vi" in your project? The documentation recommends including the "...\vil.ib\addons\_office\_wordsub.llb\_Word Dynamic VIs.vi" as well.
I have not found dynamicVI.vi or anything similar yet. Where are these files? I found a work around for now going down to core property node and invole node programming and getting rid of GOOP refferences. It was painful, but it runs and compiles. I would like to make thjis work the easy way in the future, though.
QUOTE (slubeck @ Jul 15 2008, 09:44 PM)
Dan already gave you the path to the files. They are found inside the vi.lib folder which is is found inside the LabVIEW folder. In Windows, this is C:\Program Files\National Instruments\LabVIEW x.x\vi.lib by default.
If you don't use the dynamic calls, you run the risk of having your code break when using a different version of Office, because Microsoft changes the interfaces between Office versions.
