Something I had not noticed before
dannyt
I just noticed something today that I had not seen before and it somewhat surprised me.
This is using LabVIEW 8.2.1 and I noticed that when in a case statement the scan for string does not read the format string if it passed in from outside.
Is this expected behaviour and the same in the newer version of LabVIEW ?
cheers
Dannyt
post-7256-1221556189.jpg?width=400
QUOTE (Antoine Châlons @ Sep 16 2008, 05:31 AM)
I agree the code LOOKS wrong but since that code never execustes (false constant driven state) it can't (?) produce wrong results. Imagine trying to write a "tester" that finds an error in non-executing code.
Ben
I've confirmed this behavior in LV 7.0 and 8.6.
I tried using some of the other structures (flat sequence and timed loop) and they seem to behave like the 'For Loop'. The conditional structure has the same problem. It seems that the ability of the scan from string function to see outside of a Boolean controlled structure is limited or somehow different.
Don't know if it's a bug (present in 7.0 until today) but it's not necessarily a behavior that one would expect :thumbdown:
( NOTE: A search of the dark side indicates that this is a known behavior, and NI does not necessarily consider it a bug. You could report it if it bothers you... )
QUOTE (Phillip Brooks @ Sep 16 2008, 07:14 AM)
( NOTE: A http://forums.ni.com/ni/board/message?board.id=170&message.id=190463&query.id=38753#M190463' target="_blank">search of the dark side indicates that this is a known behavior, and NI does not necessarily consider it a bug. You could report it if it bothers you... )
Nice follow-through Phillip!
Ben
QUOTE (Phillip Brooks @ Sep 16 2008, 12:14 PM)
( NOTE: A http://forums.ni.com/ni/board/message?board.id=170&message.id=190463&query.id=38753#M190463' target="_blank">search of the dark side indicates that this is a known behaviour, and NI does not necessarily consider it a bug. You could report it if it bothers you... )
Thank you for that link Phillip, it was an interesting read. I had another look at the detailed help to see if it was obvious something I missed, but to me it looks like as of LabVIEW 8.2.1 the documentation has not been updated.
cheers
dannyt
QUOTE (dannyt @ Sep 16 2008, 02:10 AM)
Definitely expected behavior. LabVIEW sometimes reads a constant format value as a help. If you care about the data types, you shouldn't rely on that but should wire in a default value for each output.
QUOTE (jdunham @ Sep 16 2008, 05:10 PM)
It would be ok if the output adapted to the format constant when VI is run. Then it should not show dbl as the datatype, it should show generic or similar.
QUOTE (Ton @ Sep 16 2008, 11:35 PM)
Oh. Guess I'll have to go tell my boss: "Yeah, I heard from the customers. Seems they don't want it. So I'm welding this can shut again. No, I don't have a clue what LV 10.5 will do for a headline feature now, but they clearly don't want this one."
QUOTE (Aristos Queue @ Sep 17 2008, 06:54 AM)
?? Please explain.....
Reference to Dynamic dispatch? Can't be since it's already in.... Hmmm.
Shane.
