Customizing the Getting Started window
Does anyone know if there is an ini setting somewhere that will allow me to change the recent file list in the getting started window?
Under the 'Open' section, it lists recent projects and files. This list matches the file..recent projects/file menu. The problem is, it only lists the two most recent projects. Since the majority of my day-to-day work revolves around several projects, I would like to change this so it lists more projects and less files. Two is just not enough and I end up using the drop down menu instead most of the time.
I know this is a minor inconvienence, but it just bugs me after awhile. There should be some why to change this...
thanks for the help,
-John
