DSC Module - Changing Citadel Path of Variables Library
QUOTE (D. Ackermann @ Dec 2 2008, 09:31 AM)
Hello
I am working on a DSC project and am having trouble to find a way to programatically change the citadel logging path of a shared variables libraray.
The application has to run as an Exe. So using the Project properties won't be a solution I guess.
I hope someone can help me on this.
Thanks
Dermot
After taking a quick glance at some of my code it looks like...
1) Stop logging
2) Use "Create Database.vi" to specify where the data should be stored.
3) Re-start logging.
Ben
QUOTE (D. Ackermann @ Dec 2 2008, 08:31 AM)
Hello
Thanks
Dermot
Dermot - what is the overall big picture? Will this be programmatically changed periodically? Will you need to detach a database at the end of a test?
In my 8.5 DSC application, we first called "Delete Process" before we created the new database. We ran into a few issues that were mostly resolved. Later today I'll dig up the old code and see what else we did that may help you.
Make sure you thoroughly test this!
