[SOLVED] <vilib>:NIScanEngine ilvce.dll missing during build
PeterB
This post is to follow up from here where I reported that NIScanEngine\nilvce.dll couldn't be found during a build I was attempting. It was a non fatal error as the exe still built.
NI gave me a solution by suppyling me with the missing directory and files (zipped up) which you install to here
C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\NIScanEngine\
Unless NI have posted these files on their website, please contact ni.com/ask and ask for the application engineer to send you a copy of NIScanEngine.zip
regards
Peter
I had the same error, but it was fatal for my build. Same solution as yours.
QUOTE (PeterB @ Jan 11 2009, 06:55 PM)
This post is to follow up from http://forums.lavag.org/-t11544.html&view=findpost&p=55706' target="_blank">here where I reported that NIScanEngine\nilvce.dll couldn't be found during a build I was attempting. It was a non fatal error as the exe still built.
regards
Peter
QUOTE (gleichman @ Jan 11 2009, 08:32 PM)
What were you using that required that dll? Some scan engine related VI? Did you have real-time installed? I'm trying to figure out how you got into this situation so that perhaps I can fix it.
thanks,
greg
QUOTE (GregG @ Jan 13 2009, 04:29 AM)
thanks,
greg
I installed LV v8.6 PDS (under/with a VLA/VLM) and the first time I went to build my application I got the error. I don't have LVRT installed.
My local NI app'n engineer told me there is already an associated CAR# but will get it to me later.
Greg are you an NI employee ? What is your motivation for fixing the problem e.g. are you experiencing it too ?
regards
Peter
QUOTE (GregG @ Jan 12 2009, 12:29 PM)
thanks,
greg
No LVRT. I have DevSuite installed with LabVIEW 8.6 PDS. I never figured out what the culprit was. I sent code into NI that was causing the problem, but due to some organizational issues on my part the submission was incomplete. By the time I got my code structure fixed, I figured that NI had the problem corrected. What do you mean by scan engine?
QUOTE (PeterB @ Jan 12 2009, 04:24 PM)
regards
Peter
Yes, I am an NI employee, and I specifically work on the code related to nilvce.dll.
thanks for the reply,
greg
regards
Peter
greg
CAR# 140034
QUOTE (PeterB @ Jan 12 2009, 10:55 AM)
regards
Peter
  • 2 months later...
