Deletion of folders and files
excuse me if this is in the wrong section...
i'm working on a vi that deletes folders/files on windows xp. when i delete something using labviews provided "delete.vi" it seems to remove the inode number of that folder/file, which means it is gone forever. is there a better method that would allow me to send it to the trash can?
sorry for linux inode reference, i'm sure windows made up some super uncool name for the same thing, but i don't know it.
QUOTE (loserboy @ Jan 15 2009, 02:17 PM)
Apparently there used to be a "G Toolbox" that contained a vi called "Delete Plus.vi" that had the option to delete to the recycle bin. Does anyone have this vi/toolbox? Was it released under a license that allows it to be given away?
QUOTE (jcarmody @ Jan 16 2009, 11:36 AM)
You could call SHFileOperation from shell32.dll with the FOF_ALLOWUNDO flag set, but it wants a custom data structure type as an argument so it would not be a trivial task.
NTFS copied many characteristics of *nix systems of its time, including the concept and name of inodes.
Side note: SHFileOperation notes (http://msdn.microsoft.com/en-us/library/bb762164(VS.85).aspx) that it was replaced in Vista by the IFileOperation interface (http://msdn.microsoft.com/en-us/library/bb775771(VS.85).aspx)... in the unlikely case that anyone is using Vista.
Joe Z.
holy crapper, you guys are friggin awesome!!!
i haven't gotten any emails notifying me of responses to this post so i was off following this "SHFILEOPSTRUCTA" and "op.fFlags = FOF_ALLOWUNDO + FOF_NOCONFIRMATION;" example i found on digital mars.com.
returning here to post my findings, and lo and behold.... you guys were here debating the merits and posting examples of several different methods! :worship:
how much more of a "christmas morning" experience can u get! hopefully i won't shoot my eye out.
thanks everybody, ALL for the inputs.
  • 9 months later...
Silly question (it may just be that my brain is slow today): where is the reference to "FileSystem" found?
Hello Jolt,
the 'reference' on the left should be a dotNET constructor node which could be found in 'Connectivity/.NET' palette. After dropping on the BD one can select the appropriate constructor (have a look at its context menu).
Within the upcoming window choose 'Microsoft.VisualBasic (8.0.0.0)', or whatever version will show up there, from 'Assembly' control. Some objects will be listed. Select 'Microsoft.VisualBasic.FileIO / FileSystem' and there you are wink.gif .
Regards,
Frank
btw: there are no silly questions, only silly answers yes.gif
  • 1 year later...
  • 1 year later...
Hello Jolt,
Regards,
Frank
btw: there are no silly questions, only silly answers :yes:
This is awesome! Thanks a lot for your tip and help on this subject. I can't believe that NI after ALL this years haven't come up with support for this! Anway, I now have VI that moves files to the Recycle Bin thanks to you !'
geir ove
  • 3 weeks later...
geir ove
The most likely reason for this is that the concept of Recycle bin is not very consistent across the different platforms LabVIEW runs on (Windows, Linux, MacOSX) and works quite differently. Also technically the Windows Recycle Bin is in fact a tacked on feature to the actual Windows core, residing in the Windows shell component which is a very chaotic collection of interfaces, both COM and procedural oriented and shows that many people have added functionality over time with VERY different ideas of how to do it. There is no central authority making sure those interfaces are consistent nor interoperable, as every product division seems to have added their own gadget with their own preferred architecture into it. Also these interfaces often chance in incompatible ways between OS versions, with APIs being added, depreciated, changed and even removed at will.
