RS232 and EVAL-AD5764EB
Silentium
Hi everyone!
I'm woking with evalboard EVAL-AD5764EB from Analog Devices. I connected it with my PC by RS232.
Data is written to the evalboard in a 24-bit word format. I try to solve this task by using VISA,
but each data-bit from 24-bit word written to evalboard in ASCII format and nothing .
How I can send 24-bit word from PC by RS232 to evalboard in non-ASCII format?
It maybe because PC RS232 logic level is different to your IC.
As i know, if you wanna connect PC Serial port to other device(not pc) you may through MAX232 or sp3232 to change level.
PC serial port voltage range is -12V to +12V, MCU voltage range is 0 to 5V.
