How do I use the HDF5 Library
Hi all,
on an instrument they want to save the data in HDF5 format.
So I tried to install the HDF5 library on my Ubuntu 10.10 (32bit) system with LabVIEW 8.5.
I installed the hdf5-tools package over the packet manager from Ubuntu.
After that i unpack the library to the LabVIEW system directory.
Starting LV I found the HDF5-VI's in the function palette. But when i placed them he asked me for the libhdf5.so library.
I found it under:
/usr/lib/libhdf5.so.6
Now he asked me for the libh5helper.so library.
I found it under:
/usr/local/natinst/LabVIEW-8.5/vi.lib/addons/_hdf5/libh5helper.so
But it seemed that the libh5helper.so file are corrupt or must be recompile. The error message is:
library not found or failed to load
So i load the source code from libh5helper.so and try to compile it but I didn't have success. (./configure -> make -> sudo make install)
So my question is:
- Did anyone else have the same problems and how did he solve it?
- How can I compile the source code of the libh5helper.so?
Thanks
Oliver
